Tig Torch Cooler Done
  • Tig Torch Cooler Done
    The Tig torch cooler is finally done. I don’t know how good it works yet as I have been trying to order a CK20 for a few days now from Tig Depot but they don’t want to answer the phone during the times they say they are there to answer it. So I got it dropped shipped from the factory through someone else for the same price. It will hold 3 gallons of water (or coolant), and is 19” X 11” X 13 ½”. I had it running and it makes less noise than the fan in the Thermal Arc 185TSW it will be connected to so that won’t be a problem.
    Pictures: 1 – Testing & setting the pump to 50 psi. 2 – Basic stuff needed to build. 3 – Back cover and fan installed. 4 – Cooler shroud build to duct air to fan. 5 – Front panel installed and cooler installed over fan. 6 – Front plumbing layout. 7 – Rear plumbing layout. 8 – Wiring done. 9 – Rear view with wrapper installed. 10 – Front view of completed cooler.
    Regards, George
    Rest of the pictures.
    Regards, George
      WOW George! Man you do nice work. I also built my water tank for my Gold Star, but seeing yours I think I’ll go out to the shop jerk it off the back of the machine, and run over it with the tractor. Twice now in the last twenty years I’ve blown up the water lines in my torch, because I forgot to turn on the pump
        Very nice, George, to heck with a coolmate, I want a genuine Georgemate!
        btw, what was the cost?
          George,
          did you know that Benard sells their cool filler plug separate.
          Nice job!! Where did you get your pan, restaurant supply store?
            Nice Job. One of the products I'm working on is an external water cooling device for computers. I also have been playing around with designs for a TIG and MIG cooler. I already have most of the components required to do a prototype - just no time yet.
            David W.
            Machines: Millermatic Passport; Millermatic 350P, Dynasty 300DX TIGRunner, TD Cutmaster 51 Plasma, Hypertherm 190C Plasma,
            Machinery and Project Pictures: Click Here
              Parts?
              George,
              Can you give us a parts list? I would hate to pay big money for a cooler when I could make one, but don't know where to start.
                George,
                That looks fantastic. Well done!
                Dynasty 350DX
                Dynasty 200DX TigRunner
                MM 350P
                MM Passport Plus
                Spectrum 375 Extreme
                08' Trailblazer 302
                  Thanks for the comments, twice in 20 years, not a bad average if you ask me.
                  Regards, George
                    Not quite sure yet as I got carried away, I will have a parts list with cost up later.
                    Regards, George
                      Originally posted by Scott V
                      George,
                      Acually I stole the bottom from my wifes old (1970's) turkey roaster. The top is the bright metal one in the early pictures, it's heavy weight anizodized aluminum. I ended up using the bottom because it seems to be coated with something that seems to be industructable, plus it has built in handles.
                      Regards, George
                        Originally posted by jud
                        George,
                        I will do that in a week or so, since I purchased some, stole some (from my wife), had some, your milage will very.
                        Regards, George
                          Originally posted by KB Fabrications
                          George,
                          Thanks kevin, I painted the wrapper with exoxy paint and got a few flaws, I need to wait a week before sanding them out so I can recoat it, it hate cold weather and will blame the flaws on that.
                          Regards, George
                            I got some stainless sheet and will have to rivet it on because I don't have a nifty brake yet. You can blame the paint on weather all you want. I had some engine enamel flake right off because it was too cold when I applied it. Me and the customer were less than thrilled - so I know your pain.
                            Syncrowave 250DX
                            Invison 354MP
                            XR Control and 30A
                            Airco MED20 feeder
                            Thermal Dynamics Cutmaster 81
                            Smith O/A rig
                              looks very profesional, nice job!
