Al welding problems - pulling out hair -help
  • HAWK
    Pete,
    Yes. A true variable polarity machine. Can't tell you much. Maybe we can see them by year end 06?
  • pgk
    Vp350
    Hawk, Fill me in on this VP350.. That wouldn't stand for Variable Polarity would it..
    Thanks Pete
  • Pile Buck
    Originally posted by HAWK
    If you hang on a while the VP350 version of the Dynasty will be available-hopefully later 06.
    Hi Hawk, thanks for the information . I never have been much of a Tig weldor. More of an LN-25 cranked up over 400-amps kind of guy. When Engloid had that Tig welding class at Miller’s training facility in Chicago a few months ago, I had the opportunity to run some machines I’ve never seen before. I was impressed with the Syncrowave 350, but when I moved over to the Dynasty 300, soon as my foot hit the pedal I was in love. I was / still am in shock at how technology has changed. I wanted a Dynasty 300 in the worst way. But with this Gold Star still working, and maybe using it 3 to 4 times a year. It’s just hard to put out that kind of money on a new machine. Have other toys / tools with priority
  • Little
    Had a problem similar to that.....Picked up a ss rod to try and weld alum It did get stuck. The rod went into a big enough puddle to where I had to cut it off cause I couldn't get it out. I changed around my rod storage set-up soon after that.
    Little
  • HAWK
    Originally posted by Pile Buck
    Well that’s good news welder-guy. I know my welder is at that age where it is either going to just die, or start nickel dime-ing me to death. But when it goes I’ll have to make the decision of buying either the Pro-Wave 300 TSW or the Dynasty 300
  • Pile Buck
  • welder-guy
    Some promising results
    Thanks again for everyone's advice. The capacitors on my Welder that were previously leaking oil are the very large, metal housing, rectangular units accessible only by removing the left side panel (when you are facing the welder) as opposed to those under the front panel. I had replaced the two smaller caps under the front panel when I first got the machine.
    I have some good news, I was able to get things working again!! I suspect that my welder is probably suffering from various worn electrical parts based solely upon its age - it looks pretty ancient inside - which are likely contributing to my problems. However, I think my biggest problem was a lack of shielding gas (yes I am stupid). Two issues combined to result in this shielding gas problem. First, my shop temperature was around 32F and at these lower temps, the regulator diaphram must get stiff or something and does not maintain the static pressure set point nearly as well as it does under warmer temps. Second, the killer cooling fan for the welder was causing a significant draft over my work area. The bottom line, I redirected the cooling air coming out of the welder and cranked up the regulator set point and things are much much better. I will continue to check the caps/points and other parts, but for now I am back in business. thanks everyone.
  • Zapit
    ATCOent---we must be using out of the same "luck" pool. That's the way it always works for me too!!!!
  • ATCOEnt
    I believe the "points" are only used for the high frequency. I doubt they are part of your "current" problem (pun intended). If your luck is like mine, your cobbled together points will fail immediately after you fix your capacitor problem.
  • Pile Buck
    Originally posted by welder-guy
    Also, there are a couple of large, rectangular capacitors that had leaked some oil a while ago. I had pulled them out, cleaned them up (thought they might have PCBs?) and tested their capacitance (no specs on what they should be - normal caps have this info listed on their case). The Fluke meter indicated about 31 uF each with no current leakage. The oil leaking has stopped, but based on the comments for you folks, I'll try to see if service parts are available.
    Bingo! I’ll bet that’s your problem. Look at this picture; the red arrows show the fluid leaking out of the capacitors, the blue arrows show the capacitors. I was told you can buy after market capacitors for like $20.00. I bought mine from Miller about $90.00 each.
  • welder-guy
    Al Welding problems - great advice
    What a great forum. Thanks for all the advice. I'll start troubleshooting by playing around with torch tilt to see if I can get things to improve, without getting into the welder hardware.
    It is very interesting that there were suggestions concerning both points and capacitors. About 2 years ago, the fancy ceramic base that holds the points cracked and I had to cobble it back together. Perhaps the alignment is not quite right and something has gone wrong - I'll check it out and try the resurfacing suggestion. Also, there are a couple of large, rectangular capacitors that had leaked some oil a while ago. I had pulled them out, cleaned them up (thought they might have PCBs?) and tested their capacitance (no specs on what they should be - normal caps have this info listed on their case). The Fluke meter indicated about 31 uF each with no current leakage. The oil leaking has stopped, but based on the comments for you folks, I'll try to see if service parts are available. Thanks again and I'll report back with results as I go.
  • ATCOEnt
    Your "points"
    Welder-Guy,
    "...black appearing on the aluminum surface and cannot reach the puddle with the filler wire without it melting back into a ball."
    I agree with everyone that the "black" is from contamination caused by lack of shielding gas. I also agree with Hawk that the filler balling "may" be due to torch position but since you have gotten good results in the past, I suspect something else. The fact that these symptoms are happening at the same time leads me to think it is, as Pile Buck suggests, the capacitors.
    My theory: If the capacitors "miss fire”, sending more current to the torch. The additional heat would (1) ball any filler material passed under it and (2) very likely increase the size of the weld puddle, maybe to a size where the shielding gas can effectively cover it any more.
    I do not know if the capacitors can miss fire as I described but from what Pile Buck says it sounds like the best place to start looking. As an experiment, you might try flooding the weld area with argon to see if that solves your contamination problem.
  • Pile Buck
    Hi welder-guy, I agree with everything that has been said here already, but just to add I have a 1980’s 330 amps Miller Gold Star. I was noticing some problems with my machine on Aluminum a few months ago. Nowhere near the problems you’re having. About 3-years ago I had to have the transformer replaced for the High freak, so I was somewhat puzzled why problems now. Come to find out the capacitors were leaking. Replaced both of them, now it works great. Not near as well as an inverter tho
  • Luna
    What polarity, filler, material and what gas? Sounds like you are running DC or you are not getting good gas coverage (due to torch angle maybe???)
  • dyn88
    I think it mat be a combination of torch angle and dirty points, Its much easier for the arc to jump backwards, does the tungsten ball up more than usual. pull the points out put them in a drill and run it on some 800 grit or so emery cloth. replace set gap and try, if this cures your problem then order a new set of points and you are off.
