Our personal best was 3.5 cords in one day. Cut, split, and stacked. My *** was dragging at the end though. It was mostly alder and maple, easy to split. Also didi that a few years ago, now I have a couple more years under my belt and dont think I would be up to it again!
Wood burning stove for garage
Welder/Fitter, I build heavy equipment attachments. ACS Coupler
Equipment at home:
Miller XMT 304
Lincoln Powermig 250
Airco Heliwelder 250
Sprint Car Crew Chief
Anyone use the old cast iron radiators and a water heater?
My goal has always been to do in-floor heat via hot water (glycol mix) if I build a shop from scratch, but the radiators would be a cheap alternative to more expensive methods. No issues with blowing shielding gasses away either.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
My sister has a house they built from scratch with infloor heat. The contractor screwed up the heat zones, but after they got it sorted, it's been a very nice system. No cold feet.
It does take longer to respond than a gas/blower heater, but if you're not losing massive amounts of heat due to bay doors opening and closing all the time, it would be ideal (like for my intended use).Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Smith O/A rig
Another option to consider would be a pellet/corn stove. The fuel is cheap ($1-2 per day). Many models have 3 or 4 heat settings that allow for a continous regulated heat output that make burning for extended periods easy. They have a hopper (30-50lb capacity) that one has to fill and the ash is easy to handle too. The only drawback is that they are not cheap. Though it might be worth the mention in the spirit of looking at all options available. Good Luck.SolidWorks Premium
SolidWorks Simulation Pro
MM210 w/3035
TA185TSW
DG Piranha II
Sharpie Deluxe
Stars & Stripes BWE
Blue Optrel Satellite
