My new toy
  • Originally posted by Fishy Jim
    Grainger.com
    You need an account though.
    Never mind that one went over your head.
    http://www.rcautoworks.com
    • That's right, because I can get those in 24's.
      Syncrowave 250DX
      Invison 354MP
      XR Control and 30A
      Airco MED20 feeder
      Thermal Dynamics Cutmaster 81
      Smith O/A rig
      • It's less about the cleanup factor and more about not bleeding as much when I wear them.
        I wish I could find latex without the powder.
        • I use these from walmart, about 5 bucks a box
          http://i3.photobucket.com/albums/y72...ardown-002.jpg
          So when welding pipe, should I weld looking at the gap from the front or the side, which is easier ?
          • http://www.grainger.com/Grainger/wwg...697514&ccitem=
            Syncrowave 250DX
            Invison 354MP
            XR Control and 30A
            Airco MED20 feeder
            Smith O/A rig
            • CRX:
              Which process for pipe welding, stick or tig? Which welding position? I am currently working on 6g with a 6011 root and 7018 fill and cover passes. I really prefer tig but around here most of the work requires that as the basis for employment then they want to teach you their way for the tig.
              For stick start with rolling the pipe and welding uphill, lifting the electrode out of the puddle straight up and down to fill and open the keyhole for the penetration and fill to be good. This is just a start point, you really need a text book for the pictures and technique.
              hope this helps,
              • Tig
                Any recommendations on a good book ?
                • 90blackcrx
                  Did I miss where you said what size pipe you want to practice tigging on? Are you trying thinwall tubing or something like 3" sch. 40?
                  • Originally posted by OldSparks
                    Trying exhaust pipe, 16 or 18 gauge
                    • Just went outside to weld some, and I could not get a spark going. Tried about 8 times and only got a steady spark two times. The arc would start, then go all crazy and stop. Any ideas on why, yes gas was on.
                      I took the torch apart yesterday to clean the insides, cause I infact forgot to turn on the gas once, but I put it back together correctly. And I tried difference tungstens and still the arc would not start.
                      • any wind? it doesn't take much......
                        • Kerosene heater but I always have that on when welding and never had this issue, I turned it off just to make sure and the problem did NOT go away.
                          • Quote:
                            I thought you just went 'outside' to weld some
                            • Outside meading outside my house into my garage. Sorry.
                              Going to turn the cfh down from 18 to 13-15 to see what happens.
                              • I turned the cfh down to about 13-15 and it helped.
                                Still can't lay a bead down on two pipes butted together. The pipe just burns and no puddle forms. And when it does form, it looks like 1 single bead. Could 18 or 16 gauge be to small ?
