My new toy
  • #91
    How do these look, besides that I need to add more filler
    http://i3.photobucket.com/albums/y72...talpics006.jpg
    http://i3.photobucket.com/albums/y72...talpics005.jpg
    http://i3.photobucket.com/albums/y72...talpics004.jpg
    I'm trying to weld t joints now, anyone have any tips cause I can't seem to get a puddle started, and when I do it just flows down.
    http://www.rcautoworks.com
    • #92
      The beads are looking better. Personally, try to get used to the puddle and how it moves in relation to the torch movements. The high definition stack of dimes look can come later in reality. I've been practicing by establishing the puddle, insert the tip of the filler and then gently move the torch along, expanding the puddle and consuming the filler. That will keep the movements on your left hand a lot less as your not dabbing the filler and give you more focus on puddle control. Having a consistent bead in width and height IMO is more important than having the stack of dimes look. Once you get good with creating nice beads with good penetration and no undercut, you can move on to other techniques to make it look cool. On steel, I like the smooth look. On intake tubing (aluminum), I like the smooth look. On certain frames and weldments, the stack of dimes look if done right looks really trick. It helps set off the fact that you are a good weldor because you can instantly pick out the process type in most cases, just by looking at the bead. You can even get the stack of dimes look with pulsing and how you move the torch. There is a lot to it.
      Do you weld sitting down, with your forearms or elbows resting on the table? Long term, you need to be universal in how you weld. However in the early stages, use everything you can to help maintain consistent arc length, torch movement, angle and filler addition.
      Fillets to me are by far the most difficult. I now know why I keep my hair cut short, as I'd be pulling it out of I didn't.
      David W.
      Machines: Millermatic Passport; Millermatic 350P, Dynasty 300DX TIGRunner, TD Cutmaster 51 Plasma, Hypertherm 190C Plasma,
      Machinery and Project Pictures: Click Here
      • #93
        Yeah I do sit down. And I'm not really trying to do the stack of dime look. I form the puddle and dip the rod, and keep moving. Sometimes I will run into the problem with the puddle getting to big, thats when I will slow down.
        So any tips on fillet welds ? Should I be pointing the arc at the gap, or should I focus it on the bottom piece.
        • #94
          Here are some of my fillet welds.
          http://i3.photobucket.com/albums/y72...letweld005.jpg
          http://i3.photobucket.com/albums/y72...letweld004.jpg
          http://i3.photobucket.com/albums/y72...letweld003.jpg
          http://i3.photobucket.com/albums/y72...letweld002.jpg
          My question is, I know you are suppose to tilt the torch about 70 degrees, but are you suppose to tilt it towards the end of the piece at all ? Find it really hard to get filler in there, and to keep the puddle moving when I don't aim towards the end of the piece.
          • #95
            Bob, who's your hand model? I wouldn't believe you actually did any work seeing those clean fingers.
            Syncrowave 250DX
            Invison 354MP
            XR Control and 30A
            Airco MED20 feeder
            Thermal Dynamics Cutmaster 81
            Smith O/A rig
            • #96
              gloves......
              • #97
                That would be me, I wash my hands a lot. I have ocd .
                lol back to my fillet question.
                • #98
                  I wear gloves too, just not constantly.
                  Any of you wear latex while working? I hated that when I was in the clean room, but I know a few mechanics who love them because of the clean up factor.
                  Syncrowave 250DX
                  Invison 354MP
                  XR Control and 30A
                  Airco MED20 feeder
                  Smith O/A rig
                  • #99
                    Tips on welding pipe? Yes, just one practice practice practice! That is the only way believe me.
                    • only when painting (especially with xylene thinned paints) and if working with oiled foundry sand.
                      hre
                      • Originally posted by Fishy Jim
                        I wear latex gloves when ever I work on cars. It sucks having to clean your hands everytime you need to go inside to eat or anything like that.
                        Ok practice on pipe, that helps. But should I be doing it like mig ? Or should I be basically looking from the side, rather then head on ?
                        Anyone know about my fillet question ?
                        • I buy latex by the 100 pk
                          • Originally posted by RadMan
                            Largest I have seen them is in 12 packs
                            • Grainger.com
                              You need an account though.
                              Syncrowave 250DX
                              Invison 354MP
                              XR Control and 30A
                              Airco MED20 feeder
                              Smith O/A rig
                              • I think you can get them in the twenty somethings up here, for the long canadian winters
                                hre
