My new toy
  • I got a picture off of Ebay. They are 3M Roloc. You could search Ebay using 3M roloc and you'll see pictures or maybe try the 3M site.
    They are really nice. The sanding disc is not too big and can be replaced. You can use it on a drill till you get a die grinder. It does a really nice job of cleaning and is cheap. I really like them on aluminum. On bigger steel projects I use a 4 1/2" grinder with a flap disc. I think when you look back in a few weeks (as you improve) you'll see that not cleaning your welding surface was a big part of the problems you're having now.
    • So whats a good welding book out there that will show me different postions.
      http://www.rcautoworks.com
      • Originally posted by 90blackcrx
        Don't know if it'll help your welding...But "Debbie Does Dallas" will show you some new positions!
        Syncrowave 180 SD
        MM185 with 3035 Spool gun
        1971 Roughneck 1e
        Stars-n-Stripes BWE
        Optrel Satellite OSE
        ESAB 875 Plasma Torch
        Lincoln 200SA Diesel
        O/A Set
        Century 250A/C-D/C BuzzBox
        1.5 kVA Spot Welder
        Phoenix Electrode Conditioning Oven
        My own shop since 1981
        Cya Frank
        • Originally posted by frank865
          lol
          Here are some more pictures from today, would of hoped I would of got better but . I still can't get the flat bead look out of here, I tried using 30 amps which was not cutting it, so I bumped it up to 40.
          http://i3.photobucket.com/albums/y72...newelds014.jpg
          http://i3.photobucket.com/albums/y72...newelds013.jpg
          http://i3.photobucket.com/albums/y72...newelds008.jpg
          http://i3.photobucket.com/albums/y72...newelds010.jpg
          I'm using a 3/32 tungsten, could that be to big for 16 or 18 gauge metal ?
          • I would drop down to 1/16" tungsten , use the 1amp per .001 rule , limit side to side motion and increase travel speed. The beeds seem awfull wide for the material thickness. The tips in the free download tig book are right on the money once you get the technique down.
            My sincere thanks , Pete.
            Pureox OA
            Westinghouse 300 amp AC stick
            Miller Syncrowave 250
            Hexacon 250 watt solder iron
            • Going to get 1/16 tungsten tomorrow, hoping that helps.
              • CRX,
                it must be chilly where you weld, in those last pic.s your weld has its "high beams" on !
                • Originally posted by PUMPKINHEAD
                  CRX,
                  Picked up some 1/16 tungsten and some sch40 mild steel pipe, 1 , 1/4 so I'm going to practice.
                  • Sch40 is so much easier to work with, but I'm still having problems, with number 1 getting around the pipe, seems like as soon as I have to start going around and down is where I loose all control
                    Anyways what would you recommend using on sch40 pipe, I'm using 3/32 tungsten but which size filler rod ?
                    I got the ripple effect down but the beads are still flat, I'm not using a lot of heat, so I don't really know where my problem is at.
                    http://i3.photobucket.com/albums/y72...x/sch40003.jpg
                    • More pics, they really don't do the weld any justic though. But the bead is still flat
                      http://i3.photobucket.com/albums/y72...ch40new002.jpg
                      http://i3.photobucket.com/albums/y72...ch40new003.jpg
                      http://i3.photobucket.com/albums/y72...ch40new004.jpg
                      If I bevel the edges, is the weld suppose to be flat ? Maybe its normal and I'm just use to regular butt welds on flat stock.
                      • Originally posted by burninbriar
                        Agreed!
                        CRX, I am learning right now as well. I have about 64 hrs of instruction from the local community collage welding program under my belt for TIG. One thing that is helping me is the rule of: “The bead should not be any wider than two times the thickness of the parent materials.”
                        I keep telling myself this rule and make adjustments as needed for this. You have the pros on this board helping you, that’s great! If you can get or go hang with an experienced TIG welder for some practical instruction. Its killing me time wise (business and family) taking the classes but I can see the learning process multiplying for me with the hands on professional instruction. Classes are soooo worth it. On that note, gota run… more stainless tonight. 4:30- 10PM!
                        Mark
                        Dynasty 200DX w/Coolmate 3
                        MM252
                        MM251
                        Hypertherm 600 Plasma
                        Ready Welder II (Trail repairs)
                        One really big hammer for the rest
                        • Your not too far off from what I can see. Just add a little more filler.
                          I would use 3/32 or 1/8 filler for that. About 130 amps or thereabouts to start. Be careful to keep the torch perpendicular to the axis of the pipe. If you lay the torch over a little too far then it will draft air into the puddle and spoil the bead. The small diameter pipe will act like an airfoil as shielding gas runs tangent to the surface and air will be drawn in the opposite side.
                          Keep up the good practice. Learn from every bead lay down. Your doing great considering the time youv'e had the machine.
                          • Thank you
                            The last pictures were done on sch40 pipe, which is about 11 gauge metal I would say.
                            My friend said the pipe looks dirty, which I cleaned the pipe pretty good ( brought it down to bare metal ) so I don't know why it still looks dirty.
                            I'm running about 80 to 90 amps, I tried using 1/16 filler rod which feels the best, I did try 3/32 but it does not really melt into the puddle like it should.
                            I talked to another guy and he said there is no way I could do it in one pass, so that maybe why its looking flat.
                            Any other suggestions ? If I bring the pipe down to bare metal, that should be clean enough right ?
                            EDITED: Just took a look at the pictures, the pics make the weld actually look more dirty then it really is. I will try to get some better pictures tonight under shop lighting.
                            The more and more I look at other people's projects,
                            http://www.psychobike.com/iB_html/up...2-DSCF0496.JPG
                            it seems like there beads are sitting flat also. So is it normal for tig beads on pipe to sit flat ? Rather then how they sit with mig ?
                            Also right now I can weld up about 90 degrees each time on the pipe, I was told this was good because anything more could cause the pipe to warp. So does 90 sound good ?
                            • New pics, I got a little concave with the 3/32 bead, less heat more filler correct ? Or just more filler or just less heat ?
                              Here is the 3/32 bead on the right, I beveled the pipe first.
                              http://i3.photobucket.com/albums/y72...sch40nn002.jpg
                              http://i3.photobucket.com/albums/y72...sch40nn001.jpg
                              Here is the bead with 1/16 filler rod, got a little crazy cause my helmet fogs. I also did not bevel this one.
                              http://i3.photobucket.com/albums/y72...sch40nn004.jpg
                              http://i3.photobucket.com/albums/y72...sch40nn003.jpg
                              • 90blackcrx
                                I understand your using 1 1/4" sch. 40. This would make your wall thickness 0.140". May not be applicable in the auto industry but boiler tube of that thickness would be welded in two passes....full bevel edges...3/32" gap...80-100 amps....3/32" filler. Picture shows 2" sch. 40 (.154" wall) done in two passes. Root pass would just come slightly shallow of flush so as to leave the clean bevel edges as guide lines for cap pass.
