A friend of mine dropped the manifold from a 6 cylinder Jeep and cracked it in a couple of places (see attached pictures). He has asked me to weld up the cracks for him. It appears that it is made from steel tubing (not cast iron). I have both a small 100 amp wire welder (no gas) and an 225 Amp Lincoln AC/DC tombstone welder that I can use. Which welder would work best? If I use the stick welder what would be the best rod to use? Any special prep work that needs to be done before welding other than cleaning and grinding?
Any suggestions would be appreciated.
