Passport (big bottle hookup?) vs DVI
  • Passport (big bottle hookup?) vs DVI
    Hello, I've been saving my money for some time now and I want to buy the best welder for money- I want to buy right once- anyway- I am an artist and have remained pretty loyal to oxy actelene for many years, olny using a mig when I was at school. Much of my welding will be thin however I will need to weld thicker to make internal armatures etc. I was looking at the DVI because it could weld 3/8in and also had the portability to go up to my cabin. The price was nice too. However the passport interests me- can I hook up a big bottle to it, or will I always be limited to the small built in bottle? I can imagine myself moving around a lot with the welder so portability is an issue however the weight of the DVI doens't scare me too much- anyway- I was wondering if anyone could help me decide what to buy? I sure appreciate it!
    Tanman
    Tanman
    Tanman,
    I own a passport unit and YES you can hook this unit up to a "shop" size bottle. This unit has a port on the rear for attaching a line to a larger external tank. My passport has performed flawlessly in both the shop and in the field. FYI I picked mine up on a Fri. and used it in the field on a Sun. I would suggest that you purchase an extra internal bottle as you might need more gas than you have on away from the shop welding job.
    I hope you get the passport and it works for you as well as mine does!
    Mike
    MACH4
      Ditto on the passport. I have one and it is a fantastic machine. It will not, however, support a spoolgun like the DVI. The DVI also has a slightly better duty cycle than the Passport as well as a better drive system.
      If I were going to do it again I would still get the Passport, no question.
      Dynasty 350DX
      Dynasty 200DX TigRunner
      MM 350P
      MM Passport Plus
      Spectrum 375 Extreme
      08' Trailblazer 302
        The Passport is an incredible machine. I'm really really and I mean really happy with mine. I picked up a DIP Tube CO2 tank, professional dump/fill station, scale and two extra bottles. I'm never left hanging needing CO2. I'll probably pick up another 20# bottle of CO2 to run via the rear port when extended welding would be necessary. But this is my portable machine, and if I had to do it over again... I'd buy one, no question about it. The DVI is a more flexible solution, offering spool gun support, better duty cycle at the top end and like Kevin mentioned, a better drive system. The Passport will do better on 110V though and that's all I use mine on presently. I don't think you can really go wrong. Miller has some nice machines out right now. I just wish I had bought the 350P instead of the 251.
        David W.
        Machines: Millermatic Passport; Millermatic 350P, Dynasty 300DX TIGRunner, TD Cutmaster 51 Plasma, Hypertherm 190C Plasma,
        Machinery and Project Pictures: Click Here
          Does anyone like the Millermatic DVI?
          I was wonderi ng if anyone could give me feedback on the DVI It seems like the passport is a great machine, but what about the DVI? Is it just kindof middle of the road?
          Thanks
            I dont have a DVI but can only say what it looks like from a potential buyers point of view. I am sure it welds well, that isnt even an issue, for me it would be do I want to pay for the ability to plug this monster into a poor welding circuit. I would rather have a 210 for the extra power and duty. The Passport is very interesting though as it is so portable. As far is going to a cabin I would add a 230V outlet if thats what it took.
              I have a Passport bought for two reasons: 1) low amperage draw, and easily easily welds nearly all of what I need on 110, I didn't have to upgrade my electrical service to run it. 2) The small size, light weight and portability, I have a VW not a truck, and I can easily toss it in to take where needed, also takes up very little room in my single car garage, a very important issue.
              You might also note that Miller rates it's arc quality above that of the DVI and the MM210 in their latest catalog.
              Manny
