I have a miller 250mp mig welder. I was wondering if there was any way to set this machine up for spray transfer. I have ben told this is not possiable due to the fact that it does not have an adjustable slope. I have a miller roughneck 500amp torch on it so the heat output is not really an issue.
Spray?
http://www.millermotorsports.com/mbo...Spray+transfer
i think this link will work, if not, do a search for "spray transfer" and you'll see a bunch of people on here discussing it.
BCBC
Coolmate 3
MM210 w/3035 spoolgun
Cutmaster 101
LC1230 12" Metal Cutting Saw
Yes you can set the MM250 MP up to do a spray transfer. A spray transfer is acheived by first haveing a shielding gas that allows for a spray transfer. I will assume that you are welding steel. You should choose a argon mixed gas that is a minimum of 80% argon with the remainder of Co2. Typically .045 wires and larger wires are used for spray but you can also spray .035.
For the .045 set voltage at 24-25 and start out very high on wire feed speed. Hold a 3/4" tip to work distance, with a push travel angle. Start the arc , and slowly decrease wire feed speed until the crackling sound of the wire hitting the weld puddle turns into a hissing sound of the wire vaporing (spraying) slightly above the material. If you have to travel too slow increase voltage a 1/2 to 1 1/2 volts and increase wire feed speed to acheive the desired fill rate.
The rate output on the MM250 is 250 amps @ 28 volts 40% duty cycle.
Try it, Gary
RDice,
If my 210 will spray with 98/2 (and it does so nicely!) you can certainly spray with that puppy! Grab up some 90/10 and go for it!
Hank...from the Gadget Garage
Millermatic 210 w/3035, BWE
Handler 210 w/DP3035
TA185TSW
