The guy kind of seems to, I don't know what you would call it. But 2 times he kind of lied to me, once he said he was 30 mins away, then he asked for my address, I mean how do you know how far away you are if you don't know where I live. Then he did the same thing about the price. Oh well we will see how it goes tomorrow
Sounds to me like your getting the run around. One of two things is going on here. Either he's really good and just too busy to get to you.... or he's really bad and not reliable. Either way from your description he sounds like a liar. Do yourself a favor an quit wasting your time on him. At the very least get a second opinion. $$He might just want to upgrade your panel.$$ The way it looks from here?? Your on your way to a pajama party and it would be in your best interest to take the petroleum jelly with you.
Neo
Best Regard,
__________________
Jesse
aka Neo
Miller Passport Miller 225G Red 255 VIctor O/A
Wish list:
Maxstar 150STH or
Syncrowave 250DX
A Dynasty 300 if I am wishing really hard..
he told me the tandem breakers are indeed against the law,
I have two thoughts. First, you already know he's a liar and poor businessman. He might be giving you a line to get a much more expensive job out of you. Though you did hear this from other sources, too, I think.
Second thought: I wonder if Kalifornia is aware that another state banned something before they did...
He is an older guy, and he keeps calling me by the wrong name also.
I think he might of thought I wanted to run a 240v of a tandem breaker , we will see if he shows up tomorrow. Today he was waiting for the fire chief to sign off on something.
I just wish I had the laws in front of me about tandem breakers
I called another place and they never even called me back.
Well that explains it and has kind of got me thinking, ...was I too hasty in my last response? Maybe a little too quick to judge? I don't think so. Senility is not forgetting to zip your pants up.... senility is forgetting to unzip them.
Well he showed up today, about 1 hour late though.
He said we would need to upgrade the box ( even though he never looked at it, but he did ask me if it was full ) he said they would have to put another, new copper tube in the ground for a grounding source. He said I would have a huge panel in the house, I swear he said it would be like 5 feet tall.
The only good thing he did say was I could run the wire along side of the house, into the garage. With another sub panel in the garage, which is ideal.
He kept stressing that it would not be a lot. Well he is leaving the estimate in the mail or front door tomorrow so we will see how much a lot means to him (which we were talking about his brother who is a multi millionaire he said )
Just a thought but they are most probably regulated on both state and local levels. Seems like I remember a some of the This Old House projects in the Chicago area where even residential wiring has to be in conduit. The main reason for this is the heavy union influence designed to create additional work. Since the code specifies minimum number of slots for each capacity panel the code gurues must be figuring there is no need for additional ckts. Your best bet is to talk to the city building inspector for electrical and he ( or she ) should be able to tell you right away if it's acceptable to use a split breaker. There is a chance it means tying 2 breakers together with a jumper to get additional amps to a circuit hence the single wire per breaker statement. A space saver breaker is really 2 individual breakers in the same case. You can bet they are UL approved and meet NEC guidelines. At any rate just go to horses mouth and get the straight skinny.
Dennis
Dennis,
This was my thought exactly.
Bob Sigmon
___________________ Dynasty 200DX w/ Coolmate 3 Miller Passport LMSW-52T Spot Welder A/O Setup with Meco Midget Miller Big Window Elite Quincy QT-5HD
Yep, my thoughts too!
Um, is it possible for you to do this job yourself? What Illinois don't know won't hurt 'em? BUT, if ANYTHING were to EVER go wrong and they found those things in the ashes...
Does the prohibition of tandem breakers apply only to new service, or to all situations? There are certain tandem breakers that are labeled as being only for existing panelboards. I really don't see what they harm, as long as the ampacity of the panel is not exceeded. Some of the larger panelboards certainly have enough room to accomodate 84 circuits, instead of 42, especially if the wiring is mostly in conduit. Putting than many pieces of MC or Romex into a panel is another matter.
