I've started looking around for someone to build a cage for my racecar and I wanted to get some advice from folks here. There's a shop that a lot of local racers use to have cages built. They all claim his work to be top notch, but they don't know a whole lot about welding so I thought I'd go over to the shop and take a closer look. After speaking with the cage builder, a few things bothered me (after seeing some awesome welds on Andy's cages). The first thing that concerned me was that on all the joints, he stitch welded them (as evidenced by a row of dimpled MIG beads). The next thing that bothered me is that he said when you weld baseplates to the floor, you have to MIG everything because the chassis sheet metal contains contaminants that only MIG can deal with (galvanizing, other weird chemicals from the car manufacturer). Oh and he's using mild steel tubing.
The guy is a pretty good engineer and his designs are sound, but should I be wary of his welding ability?
