Originally posted by harcosparky
View Post
Stopping rust on raw metal
Fwiw....
... 3M Weldable Primer
Product Name: 3M Weld-Thru Coating II
Product Number: 3M05917
"Corrosion protection coating in aerosol form designed to be applied to metal surfaces prior to welding. Dries fast in 10 minutes and minimizes MIG weld spatter. "
VERY EXPENSIVE
Regards
Joseph"Equipment Should Never be an Excuse for Poor Performance. If You are Going to be a Professional, You Get the Correct Equipment, then the Only Excuse is Your Ability to Perform." ™
When I was in the sign buisnes we used sheet metal that was already coated. We bought it by the name "paintlock". You could spot weld through it, weld it and solder it. I dont know what the coating is on it but it may be the stuff you're talking about. It was gray in collor.To all who contribute to this board.
My sincere thanks , Pete.
Pureox OA
Westinghouse 300 amp AC stick
Miller Syncrowave 250
Hexacon 250 watt solder iron
Check out www.kanolabs.com They make a long term rust inhibator. Their products, especially the Kroil works great.
More WD40 Please!
If your like me there is a number of empty cans all over. I finally found out what WD40,LPS, etc is. (Petroleum Distillate) Other wise known as diesel fuel. So just fill that old air powered spray can and have fun!Think Alot
Learn Alot
Read Alot
And Then Do It Again & Again
Originally posted by leeschaumberg View PostIf your like me there is a number of empty cans all over. I finally found out what WD40,LPS, etc is. (Petroleum Distillate) Other wise known as diesel fuel. So just fill that old air powered spray can and have fun!
JD
Originally posted by leeschaumberg View PostCheck what the % of the additives is once!
My can of WD-40 just says "contains petroleum distillates", like the cookie I had at lunch said "may contain peanuts or peanut oil". I'm not sure how that adds anything to the conversation. Please clarify.
JD
