Hi everyone, I’m looking for some advice regarding my refurbishment of an old Miller compact Blu 201
The unit was wired with 25mm2 cable (AWG 3) and 10-25 dinse fittings. It looks like someone ran it too long at max and the internal cables became hot.
the main damage is a fried single capacitor, the manual shows later models have 2 parallel capacitors but my serial number starts 0000123*** and this was made with a single FACON capacitor. It’s approximately 150mm x75mm (6”x3”) and all of the markings, other than the name, have long since gone.
I’ve had great help from other forums who guessed the value of the capacitor at 22,000uF at 63v. A High Ripple current model was suggested and maybe 2 or 3 as a bank.
I’m hoping someone can tell me the actual capacitor specifications for this model so I can get exact replacement (s) that match the electrical properties.
I’ve repaired the PCB and the transformers test good. My plan it to tear it down, refurbish the parts, clean/paint it and rebuild it using 35mm2 (AWG2) and 35-50 dinse fittings
I’d appreciate any help on the capacitor value as I may need to fabricate a capacitor frame etc depending on what is available.
I’ll post some pictures of the capacitor unit in it’s current sorry state. I’ve skinned it but there are no markings under the blue plastic. The welder is solid despite surface rust and burned electrics, it’s definitely fixable.
Im in the UK so it’s 240v 50hz
Thank you in advance
