Miller Legend aux power
  • Miller Legend aux power
    I got a Legend s/n starts KC. It will put out aux power at issue, but drops out once in high rpm. And won’t get power again at idle unless you flash the windings. What are the suggestions? Anybody think it might be the pull to weld/power delay module?
    Miller Syncrowave 250 DX
    Miller Dynasty 200 DX
    Miller XMT 350 CC/CV Autoline
    Miller Millermatic 252
    Miller Thunderbolt 225 AC/DC
    Miller LMSW-52T
    Miller AlumaPro 25’
    Miller Spoolmatic 30A
    Miller 3045 FC Wirefeeder
    Miller XR-S
    Miller Optima
    Smith Little Torch
    Victor Journeyman Torch
    Hypertherm 45
    check fuse1 and SR2 rectifier. sounds like it is not exciting the field.
      If it’s like a generator that’s lost it’s magnetism, once you flash it you’ll have to put a heavy load on it for three or four in high throttle to get the magnetism back.
        Problem is that particular machine should flash it self. Fix the problem first before trying to flash the field with an outside source. fuse1/ SR2 this is the only reason the unit is not flashing it self.
          Thanks, I will get the fuse and SR2
          Miller LMSW-52T
          Miller AlumaPro 25’
          Miller XR-S
          Miller Optima
          Smith Little Torch
          Hypertherm 45
            They are very easy to test before you get them. If you know you know.
              I checked SR2 and the fuse both seem to be absolutely fine
              Miller LMSW-52T
              Miller AlumaPro 25’
              Miller XR-S
              Miller Optima
              Smith Little Torch
              Hypertherm 45
