Maxstar 700
  • Maxstar 700
    Anyone know what HEL p-6 means on maxstar 700? Shows up AFTER powering down MANUALLY.
    Here's where you select your owner's manual, using your serial number to get the exact one for yours:
    Find replacement parts and receive detailed answers to your questions by downloading owner's manuals for your Miller products.
    Follow up and let us know if you find it there or if you need more help.
      Thank you MAC702 unfortunately manual is not helpful in this situation, not new to this btw , need someone who is familiar with this code after power is shut down MANUALLY.
        You have loose wires inside your input power plug ( likely). Quite common actually.
          Help 6 is the input voltage is to low and the unit will automatically power down. The voltage must be + or - 10% of the required input voltage.
            not likely to be a software issue, but you can try. A factory reset would pretty do the same thing for the operating system.
