Ok got another question about acetylene
  • Ok got another question about acetylene
    When my shop burned to the ground I had probably 6 acetylene tanks of different sizes. They will no longer refill these tanks after they have been in fire. The people at the scrap yard raised cain about several of tanks that was in a load of scrap I took in and said the only way they would take them is if I cut them in half. I'm old now and want to get a little older so I don't think much about taking a torch to them. I did have a small one and after much thought I started to cut it open. It seems to have a tank within a tank and once I burned a hole about 3" long in it there was a small flame that started to to come out of the hole I had cut. the only reason I decided to try it was that the valve had blown out and it was subjected to over 2000 degrees for more than an hour and I figured that anything in there had to have been burned out. This little flame burned for like 15 minutes or so and once I saw this I decided to stop right there. Now I am wondering what to do with all these tanks that the scrap yard won't take.
    Dynasty 300 DX
    Tig Runner cart with Coolmate 3
    Millermatic 252
    Spoolmatic 30A
    Lincoln Idealarc 250
    Nedeman moble fume extraction system
    Digital Elite
    Aircrafter welding positioner
    Bridgeport Mill
    Mini lathe
    4'X9' 4000lb lift table with 11/4" thick Aluminum table top
    Enerpac STB Hydraulic over air tubing and pipe bender
    4X6 band saw
    chop saw
    Dewalt porta band saw
    71/2' X 71/2' powder coat oven
    4'x4' powder coat oven
    grinders, grinders, and more grinders
    Did you see what was inside. Like asking them to pay for concrete. Drill some holes to vent, bust up with a sledge, cut open, empty, return the metal to the scrapper.
      Well I cut through the outside layer but there looks like it's a second layer about an inch deeper the the outside. The valve blew out and there is an open hole where the valve was would that be enough to vent? I might just get out the AR and vent it with a few rounds of .556 FMJ.
      Dynasty 300 DX
      Millermatic 252
      Spoolmatic 30A
      Digital Elite
      Bridgeport Mill
      Mini lathe
      4X6 band saw
      chop saw
        Throw them in a scrap car.
          Your local welding shop might take them, either free or for a nominal fee. Places that do hydrotesting and such have to scrap tanks all the time, and will have the connections to do so.
            Acetylene tanks should have a porous stone inside them, kind of like concrete I guess. That stone should be saturated with acetone, and the acetylene dissolves in the acetone. That's how they're able to pressurize acetylene tanks higher than 15 psi without risk of explosion...or that's my rickety understanding...sounds like the acetone caught fire on yours.
              I did a clean up job at a home site and had several bottles, I cut them in half with a 10" bandsaw, scrap yard saw them but did not say a word, they cut easy also, Joe
