I have a new to me synchrowave 200 that sometimes takes 3-5 mashes on the foot pedal to start an arc when on TIG. I have set the spark gap to .008 and the contacts look to be in good shape. Pedal works fine once the arc starts so I think its OK? Any ideas??
synchrowave 200 start problem
The arc just doesn’t start at all? Or the HF doesn’t fire? What mode are you in? Sometimes my syncrowave 200 will have trouble getting the HF to fire after it’s sat up for a while, but I attribute it to being in this hot and humid environment. I would expect the points to have developed some schmootz from just sitting up, but it would be hard to tell without taking them out.
Have you tried stick welding when you have that kind of trouble?
My Sync 250 sometimes does that. Dunno why. I've found that a) decreasing arc length before starting, and/or b) briefly tapping the tungsten to the workpiece before starting to equalize their voltage -- sometimes helps. Or maybe it's how I hold my mouth...seems like the planets all have to be aligned right to start the arc sometimes. (It's done this since the unit was new.) I've just learned to live with it.Last edited by Helios; 01-25-2023, 05:10 AM.
- Likes 1
Not familiar with that machine but does it have a preflow setting? Have you popped the covers on machine and foot pedal and blown it out? Clean hf points? Can you hear the hf light when pedal depressed? You should also be able to see the spark at the points once you depress the pedal. Looked inside pedal for something loose? Checked all connections? Just throwing things out there.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
