I picked up an older Machine and it has 2 torches with it. It was all unhooked when I got it.. It has a splitter valve for the gas to turn off the gas to either torch not being used. 1 torch is water cooled the other gas cooled. The gas cooled is a small A-80 type torch. My question is obviously the gas can be left hooked up but if I hook up both torches wont they to both try to arc when I used the pedal ?
Syncrowave 350 dual torch
Is it a syncrowave 350LX? How can you hook up both torches at the same time? I have the syncrowave 250DX and I have to connect my tig torch to the 14pin plug for it to work and I only have one 14pin plug on my welder so I can only use one torch at a time. how is your torches connected up? Any pictures?
regards Martin
