Miller syncrowave 250 DX help code 1
  • Miller syncrowave 250 DX help code 1
    Anyone know anything about this code? And how to fix it?
    THIS IS AN SCR OVERCURRENT. TURN POWER OFF AND ON TO RESET.IF PROBLEM CONTINUES CHECK HALL DEVICE HD1..
      Hi how are you? Thanks for your help and reply to me. I turned the welder off and on but the problem is still there it's actually gotten worse.i really can't weld in AC at all now and I can't weld in DC+ either it keeps throwing Help code 11 when I go into DC+ .I think I have a problem with the PCB 1 board. I will have to send it to get fixed somewhere. I took the board out today and it's the original board in it l think. it looks like it's been in there a long time it was quite dusty. Do you know if it's hard to repair them? Is it successful ? Does it cost much? I live in Ireland
        Help 11 is the output selector switch is not in the correct position. Check the switch i have seen them go bad.
          I got the welder fixed.its working perfectly again.pc1 had a few issues I sent it away and got it repaired. the welder runs great now. it runs so nice on AC.
            Glad to know you got the old gal going.
              Do you mind sharing who you sent your PC1 to for repair? I have a 350LX, I hope it never needs repair but it would be nice to know of a proven repair facility.
                I use Inovat never had an problem. York is my second go to.
                  Thank You for your reply Weld Dr.
                  Are the PC1 boards really a problem on the Syncrowave? My 350LX is a 2006 LG code and it spent its whole life in a college welding classroom/lab. I bought it surplus and everything worked when I tested it. Several of the 350’s had tags that said intermittent amperage fluctuation only in AC constant hf mode. My hf points were over .025” when I reset them, now .008” The toolroom guy always has a pile of Miller pedals to repair which may have been the problem too. Maybe I am being paranoid about the board. I know 2 other guys that bought the tagged welders and have no problems at all. One guy said he thought the welding faculty wanted new machines and my have fabricated/exaggerated the issue.
                  Thank You
                  Bill
