Brazing rod
  • Brazing rod
    I had to do some brazing the other day and all I have is coated brazing rod for oxy/act welding.
    Question: Can I use coated brazing rod with a TIG torch.
    Bob Miller
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    Trailblazer 302 Air Pak w/ Wireless Remote
    8-RC
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    Lincoln SA-200 Blue Tint Red Face '63
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Do you have enough to do a trial run? Scrape the flux off and try TIG welding with it...
    Richard
    West coast of Florida
      Usually a few whacks with a hammer will make it uncoated brazing rod... TIG usually uses silicon bronze, while torch brazing rods are sometimes phosphor bronze. Will it be a problem, that I do not know.
        I usually do the opposite -- convert TIG SiB rod into O/A brazing rod by heating the SiB rod and dipping it into borax. Works great.
        As for converting coated O/A brazing rod into TIG brazing rod ... bust off the flux and give it a try. I bet it will work.
          Yup, scrape the flux off and then hit the rod with some scotch brite to get it all off. If you have any on there, you’ll know it when you start flowing it. It’ll probably start spitting and sputtering at you.
