what is happening with my bead?
  • what is happening with my bead?
    So im working on some "catalytic convertor shields" for customers cars
    since im working outside and this past weekend it was really windy, ive been using gasless flux core wire to do the welding..
    I cleaned and slightly beveled the ends to do the joints. besides my unsteady hands, what am i doing wrong to get those little pits in the weld?
    From what i could find, seems these are side effects from "porosity" but im not using gas right now.. I do have mig wire and 75/25 to weld with, but last time i use that outside in windy conditions it was more trouble than it was worth.
    I have a few more orders to complete and would like to try and dial this in with the remaining orders..
    Im using 0.035 wire in my MultiMatic 200 the flat bar is 3/16 thick
    any help would be great.
    Tell us all of your settings, including polarity.
      Man, ill have to check this evening and post back, but the dial is set to "Flux Cored" setting, material thickness set to 3/16"
      NOW i will say that before cleaning up the weld with the wire wheel the weld was mostly brown and black around the edges.. the only thing i didnt do with these frames were wiping them down with acetone, i cleaned the areas where the welds were going only..
        Changing from MIG to flux-cored requires swapping the lead plugs to change polarity in addition to the dial setting on the machine.
          I agree with Mac, polarity is wrong.
            here are the connections and settings.
              Always wanted that welder
                Reduce the voltage a little
                https://youtu.be/iD7Y57gK3yU
                  Yea i remember changing that last year when i switched to flux core wire.. ill double check the settings tonight since i now have to figure out why the wire is not feeding thru the gun liner anymore..
                    Ill also give this a try, i mean i do get some good welds, but i noticed that on some i was getting the above results.
                      When i bought it, i got a great deal, it came with all 3 setup's it had a huge rebate and i also got the spoolgun with it... and so far its def paid for itself few times overs..
                        reduce V or up the speed a little.
                          For right now i had to switch over to my TIG setup, the gun liner seems to be jammed or something because i couldnt even manually feed the wire in. But im trying to get it fixed quickly so i can go back to mig welding these projects instead of TIG, but need to finish them up ASAP, so working with what i have at the moment.
                          Once i get my mig setup again, ill def try the above suggestions and see if that helps.
                          thank you
