Hi everyone, I recently acquired an older AEAD that has been sitting in the back of a welding shop for years. Serial number JC602382. I got it running, it needed the fuel pump rebuilt. I went to go check for voltage at the AC outlets and found that I only have around 1 volt there. Checked the welding outlets with the machine idled up and I also only have around one volt there.
I've been crawling all over this forum trying to hit all the trouble shooting posts about these welders and I still haven't found the cause of this problem. I checked the diode in the side of the machine and that seemed to check good. Also cleaned the bands on the two resistors but no changed after that. Those seemed like the two major causes that I came across here. I've also tried grabbing the throttle linkage and running it past 3000 rpm a couple of times but that did not help either.
I appreciate any insight anyone might have
