You need to use the taped-in wiring diagram to set the links, NOT the manual.
The pic labeled 1 is the correct configuration for 230V, but missing the third link that goes on the smaller screws. Someone may have re-arranged the wires to skip needing the third link - it looks like someone rewired it from 460V to 230V. If this has been done, you should check they did it correctly - it looks iffy to me, and there looks like there's a cut wire and a possibly overheated crimp terminal.
The pic labeled 2 is wrong. Do not power it up like that.
