Xmt 304 cc/cv
  • Xmt 304 cc/cv
    Hello! I have an XMT 304 CC/CV with a S-74D feeder. No matter what I adjust the speed, voltage or amperage to the wire feeds erratically. The power supply is wired for 230V and the whip has a new liner, new tip, roll tension is set loose and the wire tensioner is definitely gripping the wire. I've looked through countless forums and have not found a solution. HELP!
    - Joe
    Have you watched the drive rollers with no tension to see if the turn smoothly or do they turn erratically? Do they turn fast and slow as you turn the wire speed knob or does the wire speed adjustment not work? You can push the wire through the gun easily? Please post serial numbers of machine and feeder. This helps with looking at proper diagrams.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      Did the problem appear suddenly between one use and the next?
