Power Requirements
  • Power Requirements
    Hi, my name is Doug and I am new to this form.
    I am the VP and part owner of RND Automation in Sarasota, FL. We design and build custom machinery. I have the opportunity to purchase a used Miller Syncrowave 250 with cooler and torch. I have single-phase power in the shop but what size breaker will I need? And what size breaker can I get a way with? Most materials being welded will be between 16ga and ΒΌ steel.
    Thanks for your help
    Doug
    The synch calls for 100A service.
      power
      I have a 200 amp service in my shop and run my syncrowave 250 on a 30 amp breaker. never had a problem blowing the breaker.
        You will if you stand on it hard enough, it should pop a 30A breaker, if not you might have a problem with the breaker. The machine is rated for 96A @ 230 volts and I dont know if that includes the cooler. I have a 100A breaker powering mine. I'm sure the equipment is rated at max amp output with the cooling fans running.
          Welcome to the forum!
          I have the same machine and the size of the breaker depends on what you plan on welding. When I weld heavy Copper it really uses alot of power. Mine is on a 75amp breaker and I've tripped it a time or Two. When I'm welding steel I don't even get close to the top end of this machine.
          Good Luck!
          (It's a great machine)
          Bulldog
          5 Passport Pluses
          2 MM 212's
          MM 210
          MM 251 MIA
          MM 350 P w/Python
          w/ tig runner
          Trailblazer 302
          12RC w/meters
          Spectrum 1000
          Spectrum 2050
          2 Black BWEs
          Joker BWE
          Star & stripe BWE Digital
          2 star & stripe xlix's
          REAL TRUCKS RATTLE
          CUMMINS BABY
            power
            I just have been welding thin material or should i say learning. I also have the built in cooler. maybe if I have to use full power it will trip the breaker.
