Dynasty 400 purge button
  • Dynasty 400 purge button
    To find the purge you have to hold the Gas/Dig button till it shows PURG in the LH Display then you can hold it as long as you want the gas to flow or set the flow gauge meter to what you want.
    Miller Dynasty 400 TigRunner
    Miller Invision 352 MPa w/ D-74 MPa Plus
    Miller AlumaPower 350 MPa w/ XR Alumafeed Suitcase
    Miller XR-Aluma-Pro
    Miller XR-Aluma-Pro Lite
    Hypertherm PowerMax 45 XP
    Good tip, works on my 210DX as well
    Richard
    West coast of Florida
    Website
      Interesting. Thanks for sharing
        I wish I had one. Tank, regulator & welder are 8 feet away. I put a copper bar on the foot pedal. It purges & gives me constant flow to adjust CFH. I stick the tail cap in a hole in the table leg to store the torch, The tungsten is then pointed at me. I have to avoid it, or the HF is enough to reach out & grab me. It's a rude awakening when I'm careless!
        Dynasty 280DX
        Bobcat 250
        MM252
        Spool gun
        Twentieth Century 295
        Twentieth Century 295 AC
        Marquette spot welder
        Smith torches
          Works on 280DX, also.
