Ask some question about larger installs and it often includes inch pipe and it has its place but I manage with 3/4 and 1/2 and simply so much easier and easier to stock for.. My plumber bud calls for the advice the other night while him and his bud are shopping. Convince him and the bud to split a box of ground screws and 100 cable connectors. They are always trying to find one at a time.
Electrical Question
Inverters now do the work at 1/2 the input, used to require a 50 circuit now is 30 and some were 24 and now 16A actual.
The wires the machine need are now so small they need to limit the ocpd if they are used. On single voltage models they simply upsize the cord to allow them on a larger circuit.Last edited by Sberry; 10-30-2021, 06:59 PM.
We have seen ao much innovation in recent years a guy is scared to say never. It seems it might have leveled off some recently with the latest round of inverters but a new 211 is only a sliver from being able to run from a 16 cord. I am not sure what the operator might notice till it didnt work, you can tell a bit with tranny but i bet inverters not so much.
. But a tranny 211 even has cord requirements and 25 ft 14 is it. I doubt anyone could make a real argument that a 12 wouldnt help it and its something i actually tested with a 140. I used 50 ft. Wide open 4v drop 50 ft 12 and 8 with 14 as i recall. On my service it was what i could add and keep 115.
the auto 211 manual is kind of interesting, lot of subtle stuff and i only brush thru it. A difference in older single v models is they reduce the ground size requirement with the minimum wire and they make a note that the plug is not to size opcd.
this is a place a little unclear like the 30 max listing is.
- Likes 1
Dispite 30 amp listing they are desogned to run on 50 amp welding ciurcuits provided the wire is bigger than the minimum listed size. While new machines may require less power in the future, they would need another set of special adapters to meet code requirements for short cuircut interuprion.
It might just cost to much to save any money trying to cheapen the product. It is somewhat similar to buying a car to save gas milage... but this is not a perfect analagy.
But, may be cheaper to use and more reliable to use a bigger wire rather than a fuse.
I have read the manuals and its sort of interesting to note that at 120 they mention that the unit relies on the breaker for protection. They dont specifically word it as short circuit but the units have a thermal similar to a power strip where they protect the wire ahead of it. They dont mention this about the mvp adapter which is really an adapter with 30A breaker.
Originally posted by Sberry View PostI have read the manuals and its sort of interesting to note that at 120 they mention that the unit relies on the breaker for protection. They dont specifically word it as short circuit but the units have a thermal similar to a power strip where they protect the wire ahead of it. They dont mention this about the mvp adapter which is really an adapter with 30A breaker.Dynasty 280DX
Bobcat 250
MM252
Spool gun
Twentieth Century 295
Twentieth Century 295 AC
Marquette spot welder
Smith torches
Yes sir. A 20. I think rhe overheat protection is from its own thermal, the breaker is simply short circuit in the case of 120v. Built like a power strip. I guess it is at both voltages.
i am sure you are more leaened on real electric than i am. Its simply curiosity on my part as to how low they can go for service. Looks like maybe they could be able to get to 20A service ay 240 but it would likely add other code complications.
I am kind of facinated with the fireward thinki g by these guys and the code. Despite the huge changes the code changes are rather few and minor and the manf modify the machi es to stay in. I think yhey went thru the dvi stage and then got to the mvp where they figure out how to use smaller cord. The dvi required user install and prolly wasnt a problem with larger conduxtors
i think they might still do this with larger machines but not familiar with them.
