Multimatic 215 MIG wire feed motor not feeding
  • Multimatic 215 MIG wire feed motor not feeding
    Have a 4 year old Miller Multimatic 215 that I bought new which stopped feeding wire.
    The wire feed motor works: I hooked it up to a remote power source
    Tension setting and liner are ok
    No short in the MIG gun trigger
    When trigger is depressed the gas feed valve opens and feeds gas
    I did "tap" a few relays that I thought might feed the motor without any luck (read this on another board)
    Does this sound like I need to buy a new "board"?
    Thanks
    I also would check for loose wire connections, plastic wire connecters and dirty or corroded board contacts.
      On the top left corner of the PCBA there are 4 resistors in parallel (R2-R5). These should measure less than 1 ohm. If they are high resistance, you can replace them or order a new PCBA.
