Killed my Dynasty 280 DX?
  • Killed my Dynasty 280 DX?
    I just purchased a Dynasty 280 DX from CraigsList. Have been using it for the last 2 days with no problems. I like it a lot. Or did.
    Anyway... I downloaded the latest software update from Miller, inserted the SD card per directions, the light under the card reader turned green, the display went black and the light did not blink green. After 6 minutes, I removed the card. The display was still blank. I did not get a blinking red light indicating an error.
    I have turned the machine off and on several times. The display remains black. Did I kill the welder?
    Any ideas on how to get this thing up and running?
    Just a thought, does the water cooler have to running when the machine is turned on?
      Am not sure about that. Why?
        I looked up your machine in the search box, it sounded like that was a problem for an owner.
          Will try turning it on with the chiller disconnected.
          > OK... tried that. No Go.
            Tack, maybe it got hit by thunder?
              https://forum.weldingtipsandtricks.c...p?f=19&t=16236
              HTP Pro Pulse 300 MIG
              HTP Pro Pulse 200 MIG x2
              HTP Pro Pulse 220 MTS
              HTP Microcut 875SC
                Perhaps that software was corrupted ......or somewhere along its path to that welder?
                  That sounds like a bad update bricked it somehow, but I've never worked on one of those, and can't find a service manual online. I'm sure a service manual is out there, but miller doesn't make them available to random repair people like myself.
                  The first thing I'd try is re-downloading the update, making very sure it's the right one for your machine, putting it on a different sd card, and trying again. Use the mechanical clunk-clunk switch to turn it off and leave it off for several minutes, turn it back on, turn it on with the front switch, put the card in about 30 seconds after turning it on, and see if anything happens.
                  If that doesn't work, you might try giving miller an old-fashioned phone call.
                    Thanks for your suggestion. Very much appreciated. Gave it a try. It's still dead. Will be calling Miller in the morning.
                      Here is a thread about the sd card updates that was posted on a different forum
                      HTP Microcut 875SC
                        I would be incredibly peeved, as I’m sure you are. This is why I don’t update my phone, computers, etc. I don’t understand software, so I stay out of it.
                          I am not compatible with software either.
                            Called Miller. It is going in for repair. Luckily it's still warrantied until December.
                            Everyone, thanks for the help!
                              Good news, you can't do better than that.
