spectrum 2050
  • spectrum 2050
    Hello. I'm looking at getting a spectrum used however the machine has the following problem site unseen and befire i commit i wanted to see what I'm up against?
    Miller spectrum2050 plasma it will arc but doesn't continue to cut. This the quote from the seller? any ideas?
    Thanks
Name:	plas lead holder.JPG
ID:	615392 I gonna comment despite the fact I dont know anything even owning one. I learned the hard way more than once. If you are comfortable with the risk, and it's so cheap and. Insider it a hobby like the casino then it's for u especially if you are not able to test it works.
    this doesn't apply to experts that do this all the time and even then from reading g here we doing a lot of specialized speculation.
    I got another one in storage I need to re commit to digging in to. Way over my head, got to find a proprietary schematic and bring in help.
    if you got work to do buy new and get past it for a while.
      It could be as simple as a bad connection to/from the torch, or as difficult as control board level troubleshooting. The board schematics are available in the technical manual, which is a huge help in troubleshooting. But you're at odds with 800+ volts under the cover, and a few analog circuits to analyze if it's not a connector issue. You could do it without an oscilloscope, but would need a good multimeter (safe to 1000V) and some experience troubleshooting components on mains voltage.
      Hope this helps,
      Jon
        As you are aware, the problem could be one of many different components. By the description, it sounds to me like the system will produce a pilot arc but then times out and does not actually cut. There is a current sensor that detects when the pilot arc is close to the work pieces and starts cutting when this proximity is detected. The problem could be a bad current sensor or a bad control board.
