Bobcat 225. I found here in the forum how to adjust low and high idle using a Hz meter. I did that and when I check AC voltage at the receptacle, I am only getting 90vac. Do I adjust the RPM higher or look for a problem somewhere else?
Bobcat 225 Adjusting Idle/Hz/RPM and Voltage
Originally posted by snoeproe View PostPretty sure the fine amp control dial needs to be cranked up to get the auxiliary power hertz up?A FEW OF MY TOYS !!!
MX Linux
LinuxMint
Miller Roughneck 2E
Lincoln Weldpak 100
Gianttech Arc 200
- Likes 1
OK, update!!! It was on 10 when I checked it yesterday. I just checked it again to make sure, dialed to 10 it reads 90-95 volts. For giggles I dialed the fine amp voltage back and the voltage began to increase. When I got to 1, it reads 127 VAC. !!??
It sounds like the rheostat is wired backwards. You should see about 90 VAC at the 120v recept with the fine control at 1 and about 125 VAC with the rheostat set at 10. Either way, the frequency at run speed should be about 62 hz and about 43 Hz at idle.
- Likes 1
