AEAD-200 LE Questions
  • buffumjr
    Ja440003
  • Popscott
    s/n please
  • buffumjr
    Applied 12VDC to the throttle control solenoid. It responded. Will trace back to the Idle Control Board, and validate the Automatic Idle switch.. Hey! Gotta start somewhere.
  • buffumjr
    started a topic AEAD-200 LE Questions
    Yes, I know it's old.
    -On the diagram on page 17 of the Technical Manual, it says the receptacle is AC. On the faceplate of the welder, it says it is "DC while welding". This is the receptacle in the low right corner of the faceplate. What would one use this for?
    -Getting no voltage output anywhere.
    -With the motor running, and the Automatic Idle switch set to ON, the idle is about 1800. When it is OFF, it is 1800. The Technical Manual says it should be 3000. What do I look for?
    Long delayed project. Any help appreciated.
