Trailblazer 251NT with LN-25 Feeder
  • Trailblazer 251NT with LN-25 Feeder
    I recently acquired a LN-25 feeder for my 251NT. The feeder has the V/A control upgrade and is a 6 pin on the back of the feeder, is there a way to adapt this and make it work with the Miller 14 pin?
    Millermatic 250
    Miller legend 302
    Trailblazer 251 NT
    Spoolmatic 30A with WC-24
    Dynasty 300
    Millermatic 212 Auto-Set
    Hypertherm Powermax 85 (4X8 Plasma Table)
    LN-25 Feeder
    www.madsen-machine.com
    Dont quote me on this but I don’t think so. A 12rc feeder would be an easier fit for you.
    Lincoln Idealarc 250
    Miller Bobcat 250
    Thermal Arc Hefty 2 feeder
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
      The ln-25 manual I found says the remote voltage control option is a 10k pot. I think miller uses a 1k, but the input impedance seems quite high on the units I've poked at, and it's a voltage divider, so 10k is probably compatible. I don't have time to dig up a lincoln service manual and figure out the wiring - work has me way too busy lately. If the three pins on the pot are just wired to three pins on the plug, your adapter cable should be easy to make. You could also trivially modify the lincoln unit to have a miller knob and cable stuck in it.
        Or, you can sell it and pick up a 12Rc or a 12vs Miller feeder, plug in and go
        Miller Bobcat 250
        Torchmate CNC table
