Syncrowave 250 foot pedal is not working in remote but in panel mode everything works fine. I have take the foot pedal to another welder and it works fine there. I have removed the circuit board and found that R90 burned, so I replaced R90, A4, and Q13. Serial Number JK654877 Can anyone help Thanks Mike
Syncrowave 250 Foot Pedal stop working
I would check the command signal at the control board at RC6-5 in reference to RC6-4 (as shown in the attached image). If the signal makes it that far, the main board (PC1) is bad. If you don't get the 0-10 VDC at the RC6-5 connection, you need to verify that you get the 10VDC out to pins C and D of the remote 14 pin connector.
