spacer for 10lb roll? on miller 252
  • spacer for 10lb roll? on miller 252
    so i use the 10lb rolls and on my 252 i notice there is a huge gap behind the roll of wire if i center it to the roller system..do they make a spacer to stick behind the 10lb roll?...seems like an awefull poor fit for 10 lb roll it shifts side to side alot!...almost 1" of space the roll can just travel....seems very sloppy by miller to run it like this...am i doing something wroung here?
    "OUR ONLY LIMITATION IS YOUR MIND"
    You slide the roll all the way back so the rod catches the hole in the spool then add a spacer to the front.
      cool
        They used to use a spring to hold tight against the back, not sure about now. If you don't have a spacer or spring you can just cut a pc. of pvc pipe to the right size.
        MM250
        Trailblazer 250g
        22a feeder
        Lincoln ac/dc 225
        MM200 black face
        Lown 1/8x 36" power roller
        Arco roto-phase model M
        Vectrax 7x12 band saw
        Miller spectrum 875
        30a spoolgun w/wc-24
        RCCS-14
          Every old wire feeder I've seen comes with a piece of drain pipe or electric conduit cut to the right length...
            Miller part # for the spring 057745
              This is what I mentioned. All older feeders/machines had this. Any metal or pvc pipe will work also.
              Click image for larger version  Name:	20210415_172340.jpg Views:	0 Size:	1.51 MB ID:	614552
              Click image for larger version  Name:	20210415_172352.jpg Views:	0 Size:	1.39 MB ID:	614551
              MM250
              Trailblazer 250g
              22a feeder
              Lincoln ac/dc 225
              MM200 black face
              Miller spectrum 875
              RCCS-14
