how many amps for brass ground clamp?
  • how many amps for brass ground clamp?
    my miller 252 is coming monday i always wanted the brass ground clamps they work great is 400 amp brass clamp enough?
    "OUR ONLY LIMITATION IS YOUR MIND"
    Yes
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      You need a ground clamp rated for at least as many amps as your machine. A 400A clamp is more than sufficient for a 250A machine.
        Hmmmm....Miller calls for an 8ga ground conductor, and 8ga wire is only rated for 40-55A depending upon which type so I'm confused. Ohhhhh...you guys are talking about a work clamp!
          Yes. They are talking about a work clamp.
          I suggest a c clamp type ground/work clamp for mig. I always seem to have trouble with grounds and get machine gun starts.
          Dynasty 400 Wireless
          Coolmate 3.5
          Aerowave loaded with Sequencer and pulse
          ​Watermate 1A
          XMT350 CC/CV
          S74DX Feeder
          Optima Pulse Pendant
          WC24
          30A spoolgun
          Neverlast 100 amp plasma with Hyper Duramax torch
          Avortec 280 mig
          GO CNC Poweredge CC/CV pulse and double pulse
          Harris Old school 2 stage Oxy/Ace
          Victor flow meters
          Flametech Duel flowmeter
          Just a hilljack in the woods with fancy welding equipment
          and a pet Raccoon.
            I know, I was just teasing a little.
            Now that I think of it, if the negative lead is "grounded" no welding is going to happen....lol
              Hmmmm....Miller calls for an 8ga ground conductor, and 8ga wire is only rated for 40-55A depending upon which type so I'm confused. ...
              Because you're ignoring duty cycle. Read Article 630 in the National Electric Code.
              EDIT: Oh, sorry, yes, I'm with you. It's a work clamp, not a ground clamp. It can be any polarity, and it is not at ground potential when in use.
