will spoolmate 3035 work with miller 252?
The column on the left are listed Miller welding power sources in that class, the column on the far right gives you what peripherals, if any, you need to operate that spoolgun, and on the same line as the power source you want to use, Miller has stated they think you should probably not chose that option.
