I have a Miller Pipe Pro 304 and a S-75D wire feeder that I am trying to get to work together. I can get it to weld pretty nice but then it seems no matter what I do when I release the trigger it pops back and melts the tip. I've tried different wire feeds (150-250), voltages (19-24), dig settings.
The setup is as follows: Gas 100% CO2, Wire .035 Lincoln L-56 (ER70S-6) Wire. All leads are new 1/0, new ends, Tweco MIG-600 ground clamp.
The CP-302/S-75D combo works pretty well No such issue. Just doing test beads on some 1/4" A36 plate. Using wire feed speeds between 150 and 250 and trying to tweaking the voltage for a good arc.
No matter what I have tried I can't get it to end without messing up the tip almost every time with the Pipe Pro.
Any ideas?
Any ideas?
