because resistor gets hot quickly don't want to run machine too long.
Syncrowave 250 issues
I recently acquired syncrowave 250 cc serial number kh470070. I been having issues with R7 running hot especially in AC mode. I measured 1.6amp across the resistor in ac and 800 milliamps in DC mode. I checked the rectifiers sr2 and sr3 with a multimeter both were fine. Also changed the cr2 and cr6 relays thinking that was a issue. I'm planning to change all of them they looked little worn. Also checked the resistance across the transformers they are all fine. I'm lost what it could be. I didn't weld with the machine yet Syncrowave 250 issues
That's a 100W, 50ohm resistor, so it looks like the RMS amperage is measuring out close (AC seems to be about .2amps high). What is indicating that it is getting too hot? I would expect worse case.for that resistor is open circuit voltage. The current through it would drop when the machine is under load and output voltage is in the 12-36V range.
