Andy ,
I have a hobart 175 handler welder about 4 years old . It wont feed . It will feed with out any load no wire , no tension roller . It will only feed threw the lead on wide open , wire speed maxed. If you turn the speed down it stops.
I have put a volt meter on the wires to the feed motor . When it stops it has no voltage . Can anyone help me with this problem ? Also it has a new liner in it .
Thank You !
Thank You !
