Hi all new on this page, so posting my first problem, we have a CP - 200 Ser.# 72- 642248 . Problem will start fan is working wire is feeding but no spark, started by scipping but now nothing ? I know its old but so am I.
Miller CP-200
I have fixed some with bad connection issues in a few spots. If you're showing voltage on the output (either on the meter or measure voltage across the lugs), then it could be from either the primary brushes are stuck or dirty (left side if you're looking at the panel, three sets brush against the primary could), it could be in the wiring to/from the transformer (shine a light to the back side of your 208/230/460 voltage tap panel), or it could be on the connections to/from your rectifier (big diodes screwed into the aluminum plates that form around your fan, if that makes sense).
If you're not getting any voltage and your contacts are good (and the contactor engages when you hit the trigger), it could be either a broken connection above. I think bad rectifiers is less likely your problem, so it's worth cleaning out the machine and checking the things above first.
- 1 like
