I got a used 2050 from a guy that swore it worked fine for him (maybe). It seems to be in good shape, ICE-55C torch, decent consumables, the air filter is dirty but everything else was fine.
The Pressure light stays on and the torch is giving lots of air but no plasma, the trigger on the torch does nothing to change the lots of air and lack of plasma. I jumped the pressure switch and nothing changes. I verified the inlet air pressure and the pressure in the system by changing the regulator in the 2050 and the one on my compressor. The voltage and amps it's getting is good.
I'm just checking to see if there's any obvious fixes or diagnostic tests to narrow down my issue. The o-ring seems OK as do the rest of the consumables but I can look at changing them out, I just don't think that has anything to do with the issue.
Any thoughts or ideas would be helpful. Thanks!
