Syncrowave 180 Gas valve problem
  • Syncrowave 180 Gas valve problem
    I have a Syncrowave 180. It does not have the digital display. The Gas valve opens as soon as I turn the unit on. I checked the foot pedal its working properly. Checked without foot pedal connected still turns on. Are there any schematics available of the board. I do have electronic equipment to test such as meters and a scope. Thanks
    Serial number ???
      The serial # is KK066257 . Appreciate the help.
      Thanks
        Before you go looking at the board, check the gas solenoid. Is it receiving power to turn on, or is it just stuck on?
          Receives power as soon as welder is turned on, opens and wont shut off till power is switched off.
              Thank you very much for the schematic. I'm suspecting Q4 shorted or diode D15 ??? I have the board out on the bench.
                Checked Q4 in "diode mode" seems to be shorted Source to Drain. Continuity in both direction.
