Miller SCP-200C with Millermatic 10A need help wiring it up.
  • Miller SCP-200C with Millermatic 10A need help wiring it up.
    I have a Miller SCP-200C and a Millermatic 10A. The problem I’m having is I can’t seem to find a diagram on how to wire the power supply to the feeder. I have the connectors that go to both but no diagram to wire them together. Does anyone have this setup and can help?
    I've had Miller equipment from the same era. If I had pics of what you were looking about, I'd bet I could tell you what to do with it.
          So on the front of the power supply the positive and negative studs I assume you hook the positive to the remote wire feed but where? And I assume the negative You hook a long cable with a ground clamp correct?
