So the tl;dr story is going through my dads garage, found old Miller Bluestar 1E welder (s/n HH072828). 16hp Kohler motor, electric start (s/n 3072093) What is it’s value and is it worth trying to fix?
So now the rest of the story...
My dad has been dead for 15 years now and he was a swap-meet-aholic. I’m not sure what time frame when he purchased this beast but the battery was installed in 1989. I asked him about the welder and he told me that he got it running, rebuilt the motor. Then he lent it to one of his friends that he said didn’t run the engine at full power when welding and burned up a winding. I can’t confirm any of this until I can get the welder operational.
Fast forward to today, my sister and I are cleaning out the garage and this is tucked in the back. I have all the documentation on it. Notes my dad had made. From what I saw from his notes it threw a piston rod. Only reason I say this is he highlighted the parts he needed in addition to his rebuild notes. So he was an auto mechanic and rebuilt the Kohler engine, though I’ve never seen it running.
So I am looking at this and on my list of stuff to get is a new battery for the electric start. I got a new fuel line as well; the old one was old and brittle. I’m making the assumption that it is a gasoline engine. The Kohler manual talks about straight gas (LP), combo gas-gasoline, and kerosene fuels. From looking at the unit it looks like a gasoline model. I don’t see any fittings that would suggest an LP hookup. I don’t want to add any fuel to the tank until I figure this out.
I’ll include a few pictures and maybe this forum can give me some tips and pointers about this model.
I am not a welder either so you’ll have to ELI5.
Reading about the settings though, if you were to weld with the switch in power mode, wouldn’t the engine not be at the proper rpm and thus not allow you to make a spark? The manual says weld switch rpm is about 3000.
So if I do get this running what should be the first thing to do?
Thanks for reading!
