Did all the prepower check on xmt350 serial md4204 (except when igbt tester was needed, do not have one yet) all tests were within specs exept r1 &r8 bleed resistors on interconnect board pc2 reading about 34k threshold is 37-41. Assumed they were bad but when tested with everything unplugged it then reads within specs. Found that only when plug RC3 is connected the ohms drop out of specs, found that pins 1,2,5,6 on rc3 plug on interconnect board cause drops which ties into pc1 control board pins 4,5,6,7(common primary bus -, igbt gate drive signal and return).
Questions- I am assuming the only problem is on pc1 board? Is there a way to troubeshoot the more exact problem? If so and if someone knows the most likely issue can just that be replaced on the board?
Side notes- If possible I do not wish to replace the whole board if possible since they are are costly, I have someone who does board repairs but just need to point him in right direction of what needs to be repaired.
I have attached some picture of manual and if anymore need to be uploaded let me know. Thanks for any help!
