The service manual for the Hypertherm 85 has a section on testing the IGBT
using the Hypertherm tester as well as a home made one.
The schematic f0r the home made tester is included.
Pages 5-12 thru 5-16.
https://www.hypertherm.com/en-US/sup...=English%20(US)
xmt prepower check igbt
Is a cheap tester like this something that would be able to do the job?https://www.ebay.com/itm/372864022690
Thanks for reply.. Ok thats what I thought I would need a ibgt tester but was hoping I could get away with using something else. Well guess I'll be getting a igbt tester bc I have 8 of these to work through.
Is it simply enough you could tell me how to do a test once I have a igbt tester?
Those are additional tests you can perform if you have an IGBT tester. You can make a simple one with a 9v battery an LED, and a couple resistors.
I am trying to do the prepower check on some xmt 350s and I am unfamiliar with what they are looking for me to do with the igbt testing (circled in picture). Also I only have a multimeter so any help would be appreciated1 PhotoTags: None
