xmt prepower check igbt
  • xmt prepower check igbt
    I am trying to do the prepower check on some xmt 350s and I am unfamiliar with what they are looking for me to do with the igbt testing (circled in picture). Also I only have a multimeter so any help would be appreciated
    Those are additional tests you can perform if you have an IGBT tester. You can make a simple one with a 9v battery an LED, and a couple resistors.
      Thanks for reply.. Ok thats what I thought I would need a ibgt tester but was hoping I could get away with using something else. Well guess I'll be getting a igbt tester bc I have 8 of these to work through.
      Is it simply enough you could tell me how to do a test once I have a igbt tester?
        Is a cheap tester like this something that would be able to do the job?https://www.ebay.com/itm/372864022690
          The service manual for the Hypertherm 85 has a section on testing the IGBT
          using the Hypertherm tester as well as a home made one.
          The schematic f0r the home made tester is included.
          Pages 5-12 thru 5-16.
          https://www.hypertherm.com/en-US/sup...=English%20(US)
