XMT304 Help7
  • #46
    Well, that's progress at least! Something is overloading the +15V supply. it should be a solid 15V, absolutely not 12.9V. When the supply voltage drops, the bus unbalance detection circuit can give a false trigger, which explains the help7.
    I'm way too tired now to poke at the schematic and see what else you should check, will see if I have time tomorrow morning.
    I don't have the correct schematic for that serial number, so I can't look up what R250 is. I wish miller would make it available, or someone on here could find a copy and scan it...
    If you can, try getting a thermal image of the front control board.
    • #47
      My *******s neighbors didn't let me get any sleep again last night due to their 24/7 party, and I'm too tired to function, much less analyze schematics. maybe tomorrow.
      • #48
        R250 looks to be in the same location on your board as the board in the TM. It looks like it is in the 230V contactor power circuit.
        • #49
          Okay I tried to get a good thermal image of the front board but couldn't figure out a good way peaking in from the sides, no components stood out as hotter than others
          I did remove PC2 so i could test the diodes from the back and got some results. D1 showed 320kohms in one direction and 77kohms in the other direction. D2 showed 220ohms in both directions which I think is definitely not good. The manual shows that both are supposed to test at 2000ohms.
          • #50
            Harry, just use your diode tester. I'll check out my spare PC2 in the morning, but I don't think anything is in parallel with those diodes once PC2 is removed from the machine. You're really confirming they aren't showing 0 ohms.
            Measure both directions from R1 to L3-2, then measure both directions from R5 to L4-2.
            If you still get the same readings, please post pics if what you are measuring.
            • #51
              Also, it's worth pulling RC4 off PC-1 and checking resistance across pins 4 and 2, as well as pins 1 and 3. Resistance should be 7.5 ohms.
              • #52
                I did also check it in diode mode on the multimeter and got D1 OL and 0.33v and D2 0.084v and 0.087v
                • #53
                  D2, or something in parallel with it, sounds distinctly unhealthy.
                  • #54
                    Can you post pictures of your board, particularly around D2 and the PM2 connections? The board and schematic I have show nothing in parallel with D2, just want to confirm your board is the same. Also, have you checked PM1 and PM2 with the board off?
                    • #55
                      [ATTACH=JSON]{"data-align":"none","data-size":"medium","data-attachmentid":610356**[/ATTACH]
                      [ATTACH=JSON]{"data-align":"none","data-size":"medium","data-attachmentid":610357**[/ATTACH]
                      I’ll try after work today to check PM1/2. I did measure RC4 with PM2 removed and I got 16.6Mohms and 16.4Mohms respectively.
