Miller M-180P multi voltage wiring help
  • Miller M-180P multi voltage wiring help
    I have an old Airco welder that is identical to a Miller M-180P. It didn't work when I got it and it appears that it was wired wrong. This is a multi voltage machine capable of running at 230, 460, and 575 volts. The manual shows jumper locations for conversion but does not show specific wire locations. Does anyone have this machine and can help me with wiring placement from the primary coils?There are 5 wires from the two primary coils to the terminal block. I have attached a picture of the terminal block in the machine for refference.
    I've also looked in the owners manual (no tech manual available) but I happen to have a manual for the MSM Busybee 180 amp machine.
